1998 B20b swap civic start then stalls
Old Jul 19, 2021 | 11:24 AM
2jz240sx's Avatar
Default 1998 B20b swap civic start then stalls
Hey guys I have a question regarding an issue I've been fighting too fix. I was on my way too work this morning and all the sudden I had less and less throttle response, if I tried too push the pedal too correct it, it would loose all engine power and begin too die. I eventually pulled over too the side of the road and turned the car off, I checked everything out and went too fire it up. It started but I had too dance on the pedal too keep it running. But that only worked for maybe 30 seconds. Fuel pump primes no issue, there is no check light but now it starts and immediately stalls! I checked all the grounds and fuel lines no leaks no vacuum leaks either. I have great spark new dizzy, plugs, wires, cap, rotor, iacv, map sensor, o2 sensor fuel pump, tps. My fuel pressure is 48psi when I prime it. I'm lost because I was able too get the car too run on starting fluid, what gives? I'm currently running a chipped p28 with jumper harness have been for over a year since I built the car.
TimKennard
Jan 2, 2011 10:04 AM
brianfromhawaii
Jun 16, 2009 11:44 PM
y0whuddupb
Jul 20, 2006 10:14 PM
