Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2013 Accord won’t run after timing belt replaced
Old Jul 19, 2021 | 06:55 AM
theboz's Avatar
Default 2013 Accord won’t run after timing belt replaced
I have a ‘13 Accord EXL with a 3.5l vetch. After replacing timing belt it starts but runs roughly. All timing marks are lined up. Is there something I’m missing that would cause this?
Old Jul 22, 2021 | 05:46 AM
RodWolf19's Avatar
Default Re: 2013 Accord won’t run after timing belt replaced
Why did you replace the belt? Was it maintenance or did the old belt break?
The crank sprocket may have a dot and an arrow on it, can you verify that the arrow is lined up with the arrow on the block and that the cams are also lined up?
Old Feb 3, 2022 | 02:56 PM
Jeeksta54's Avatar
right i heard on this year model you dont need to replace it.
Old Feb 3, 2022 | 03:09 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
V6 timing belt still needs to be replaced. 4 cylinders had a timing chain, which is not what the original poster has.
TechBob
Mar 25, 2024 06:04 AM
88Hondaman
Classic Hondas
Apr 25, 2016 06:29 PM
Two400
Jan 22, 2008 04:10 PM
NewfieAccordEXR
Sep 3, 2006 01:06 PM
