Wireworx Harness
Old Jul 19, 2021 | 03:30 AM
quenepon69's Avatar
Default Wireworx Harness
I am about to install the Wireworx engine harness and headlight harness.. For the engine harness, on a 93 Civic SI with a B18c turbo, my issue is hooking up the plugs inside the car and what goes where? Any threads out there explaining better how to install? Wireworx was not really that helpful, the headlight harness has instructions but doesn’t really explain the AC part of the wires..
My build
Old Jul 20, 2021 | 07:01 AM
KiNGDEE206's Avatar
Default Re: Wireworx Harness
if similar to other style custom harnesses that requries chassis harness
there should be 4-5 plugs ecu side
3 goes to ecu
1-2 goes to the kick panel “c101” or something like that the “cabin/chassis plugs thats literally next to the “check engine light checker connector”
1-2 goes to “chassis harness”
then the other end of chassis harness goes to driver side shock tower
do u have a chassis harness also? / if it requires one?
idk anything on headlight harness
Old Jul 20, 2021 | 07:05 AM
iwannarace's Avatar
What did you use (brand / color) to paint the trans and engine? Looks niiiice.
Dorkenheimer
Apr 4, 2016 09:51 AM
$MIKE$
Jun 10, 2014 12:47 AM
bradennicely
Apr 25, 2010 04:36 PM
92GSRHB
Jan 31, 2009 05:09 PM
