Honda CR-V & Element 2WD & 4WD Element & CR-V
2010 Honda Element P2A00 OBD2 Code
Old Jul 19, 2021 | 12:42 AM
TavoG's Avatar
Icon4 2010 Honda Element P2A00 OBD2 Code
I Recently Replace both oxygen sensors on my 2010 Element and got this code P2A00 Code on a Scanner, Sensor B1 S1 Circuit, and don't know why I got this code after running the car for few days without an issue.
OBD2 Scanner Code
Old Jul 19, 2021 | 06:15 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2010 Honda Element P2A00 OBD2 Code
There are two codes, post the second code too.
Old Aug 20, 2022 | 09:31 AM
DJCHOPSHOP's Avatar
DID YOU FIX YOUR O2 SENSOR PROBLEM? 2011 HONDA ELEMENT CODE 2A00 CHANGED UPSTREAM O2 SENSOR COUPLE OF TIMES CODE COMES BACK WILL TRY DENSO TODAY
Old Aug 20, 2022 | 11:59 PM
DJCHOPSHOP's Avatar
[QUOTE=DJCHOPSHOP;52619190]DID YOU FIX YOUR O2 SENSOR PROBLEM? 2011 HONDA ELEMENT CODE2A00 CHANGED UPSTREAM O2 SENSOR COUPLE OF TIMES CODE COMES BACK. Also first code is pending code second code is confirmed
Old Aug 22, 2022 | 06:17 AM
DJCHOPSHOP's Avatar
UPDATE 2011 HONDA ELEMENT HAD TO REPLACE UPSTREAM SENSOR A FEW TIMES FYI STICK WITH FIVE STAR REVIEW THE OTHERS ARE NOT HOLDING UP BOUGHT MARSFLEX AND DENSO MARSFLEX FIXED THE CODE 2A00 FOR NOW
I PURCHASED DENSO UPSTREAM O2 SENSOR DENSO DONT MAKE AN UPSTREAM SENSOR FOR HONDA ELEMENT PER REPRESENTATIVE FOR DENSO THAT 2A00 CODE WILL GIVE YOU NIGHTMARES PUTTING IN WRONG PARTS. DENSO OR NOT DENSO ? FYI MARSFLEX 234-9064 5 STAR REVIEW CLEARED THE CODE 2A00
Last edited by tech8; Aug 23, 2022 at 03:28 PM. Reason: Posting essentially same things in separate posts.
dinamozagreb
Jun 27, 2017 07:21 AM
Ready4lyf
Apr 22, 2011 06:53 PM
black_99SI
Dec 7, 2007 05:14 AM
SexyHatchie
Aug 22, 2007 04:44 AM
spoonek4
Apr 6, 2003 01:23 PM
