H23A w/ BC Stage 2 Camshafts: Cam Degreeing
I'm building a H23A bluetop and I'm using the Brian Crower stage 2 NA camshafts. I'm using the H23A block and bottom end, and a H22A head that I had built. Using the BC cam card, I set cam timing using both their indicated cam timing events at 0.050" lift and using the centerline method, double checking everything. Both methods resulted in the exhaust side at +4 (advanced) and +2 on the intake side. I know this isn't a wild camshaft profile so I'm a little surprised at the number of degrees it needed to be advanced. I figure the H22A head probably had some previous milling done which I would think would cause the cam timing needing to be advanced, correct?
Any of you set cam timing with these camshafts and if so what did you end up with?
neofreak
25
Jan 1, 2007 12:33 PM
