Assistance Needed 2002: Honda Accord F23A1. Cranking but no start issue.
Old Jul 13, 2021 | 02:28 PM
Mannydee's Avatar
Default Assistance Needed 2002: Honda Accord F23A1. Cranking but no start issue.
Hi so I'm new to this my 2002 Honda Accord f23a1 cranks but doesn't start it's get gas and spark what else could cause it from not starting
Old Jul 14, 2021 | 03:25 PM
Sic_DA_Nine's Avatar
Default re: Assistance Needed 2002: Honda Accord F23A1. Cranking but no start issue.
compression.
any recent work to your vehicle prior to the issue?
check timing
Old Jul 18, 2021 | 11:53 AM
SeventeenYears's Avatar
Engines need three things to run...air/fuel/spark. Did you snap a timing belt?
Old Jul 19, 2021 | 09:55 AM
TheShodan's Avatar
Moderator
Default Re: Assistance Needed 2002: Honda Accord F23A1. Cranking but no start issue.
Here's where you want to start. take a look at this video and follow the steps. Eric The Car Guy is great for beginners and refreshers alike. Please be kind enough to let is know what you've found so others can gain knowledge from your experiences, whether they be good or bad.
Old Oct 18, 2021 | 01:18 PM
feels's Avatar
This model still use spark plug wire (with spark distributor), so you could mix up on the spark plug wiring connector to the spark plug.
If you removed the camshaft before, then you might accidentally reverse the slot that connects to spark distributor, and mix up the spark firing sequence.
It will be helpful to share with what you done prior of the issue from happening.
frankmosqueda
Sep 18, 2018 04:08 PM
hondahbgurl
Jan 2, 2012 05:44 AM
