Down pipe to cat making loud noise at high rpm.
Old Jul 12, 2021 | 04:28 PM
jstmeseg's Avatar
Default Down pipe to cat making loud noise at high rpm.
99 Honda civic EX, manual trans. Just recently had to cut my old exhaust bolts off and replace the gasket and exhaust header gasket. But now when i drive its like at high rpm there are exhaust gases pushing through thay point and the exhaust has a slight seperation. And its loud as hell like a sratching, screaching noise. Ive replaced the hardware, a new gasket again but for some reason it still doing that. And i dont think a clogged cat converter would do that cause im still getting air through exhaust. But could a clogged cat force the air to push itself through that point. Cant seem to find anything on it or someone having the same problem. Thanks.
Old Jul 14, 2021 | 12:33 AM
Harrymonk's Avatar
Default Re: Down pipe to cat making loud noise at high rpm.
I've had the same issue with mine for a few years, the screeching mainly occurs on deceleration at high revs. I believe its the donut gasket but I've tried high temp silicone and hasn't solved the issue. It's very hard to diagnose with the car stationary
YoungKadafi
Mar 12, 2007 12:08 PM
732xghost
Nov 16, 2006 07:08 PM
Jordans95si
Aug 22, 2005 11:50 AM
jwb009
Sep 20, 2004 09:59 AM
-[95cxhatch]-
Nov 6, 2003 05:47 AM
