Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2008 CIVIC DX OVERHEATING WHEN IDLING BUT.....
Old Jul 10, 2021 | 10:59 PM
Zay_FA1's Avatar
Icon4 2008 CIVIC DX OVERHEATING WHEN IDLING BUT.....
When driving car over heats, but if I turn heater on, temperature eases back to normal, and is good to go unless I turn heater off again. Even when in idle doesn't run hot with heater on, but if heater is off it over heats.I put new thermostat radiator and yes I know what about the water pump well I want to see before I buy this expensive part see what else it can be before buying it. thank you!!!!
Old Jul 10, 2021 | 11:24 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2008 CIVIC DX OVERHEATING WHEN IDLING BUT.....
Are your cooling fans running when the car is overheating at idle?
If your car is equipped with A/C. This is how the cooling fans operate.
Generally, both cooling fans (radiator fan and A/C condenser fan) should be running at the same time; high coolant temperature or A/C is on.
When coolant temperature is above 206_F (97_C), both cooling fans should run. (High speed)
When A/C is on, both cooling fans should run. (Low speed)
When A/C is on and if the refrigerant pressure rises above 1520 kPa(221 psi), both cooling fans should run. (high speed)
Old Jul 11, 2021 | 07:26 AM
Zay_FA1's Avatar
Yes both fans do run i also forgot to mention i replaced the a/c fan and temp sensor as well.
Zay_FA1
Jun 29, 2021 12:35 PM
Katlyn Hezinger
Dec 7, 2017 04:54 PM
barrybong34
Aug 6, 2015 12:29 PM
Kanjo EF
Apr 22, 2015 01:24 PM
thebox11
Apr 20, 2006 07:48 PM
