03 CRV compressor not engaging
hey guys I need some help. I read some forums earlier but they aren't exactly tailored to my exact issue.
03 CRV compressor wont engage. put gauge on there, low side high around 90 and high side low around 150.
checked and swapped all relays and fuses related to the ac...both fans work. tried jumping the compressor from battery, nothing. checked for power coming from the wire connected to compressor, nothing. i put autel scanner on it and it showed me that the ac switch is able to go to the on and off position when pressed. if you guys could help me out that would be appreciated
I have the same issue. I have usually just replaced the whole compressor and clutch together ( the usuall compressor failure on all of my last 4 CRVs) but this time I may just replace the clutch on the current 2006 unit. As it faded out over a couple of days. I need to check my compressor first as well.
bighoss77
Jan 28, 2012 04:59 PM
JesseCRX
23
Aug 11, 2008 04:40 PM
