What is this bolt on D16Y8?
Old Jul 8, 2021 | 12:41 AM
NaymzJaymz's Avatar
Default What is this bolt on D16Y8?
Hello, please tell me what this bolt is for on the D1ZY8 engine eight engine(upper left of the oil filter). Thanks.
Old Jul 8, 2021 | 05:54 AM
Ryanthegreat1's Avatar
Default re: What is this bolt on D16Y8?
Crankcase core plug. Just a cap to cover the hole in the crankcase left from the manufacturing process.
Old Jul 8, 2021 | 03:58 PM
NaymzJaymz's Avatar
Thank you, Sir Ryan!
Old Dec 4, 2021 | 10:03 AM
spolkyc's Avatar
Looks like the coolant drain bolt on the block. It leads to the bottom of the coolant jackets around the cylinders, behind cylinder #2. You can see the light behind cylinder #2 in the bottom of the coolant jacket, in the picture, from a flashlight in the drain hole. The blue shop rag, on the pulley side of cylinder #1, is in the inlet from the water pump.
(pg 10-7, '96-'00 Civic Service Manual)
foodkeeper
May 8, 2012 12:19 AM
platanodom
Aug 8, 2007 05:10 PM
imaginary17
Jun 13, 2004 03:24 PM
Runsw4g4d
Sep 27, 2003 02:49 PM
