EJ6/EJ8 front lower control arms
In the UK, the 6 gen civics has one piece pressed steel front lower control arms, whereas the 5 gen EG has two piece cast steel. My ej6 has two piece cast even though its a 6 gen so if I wanted to get uprated front lower control arms, will the EG ones fit as there is no listing for 6 gen two piece uprated arms? Otherwise it would be a case of changing them over to pressed steel and then having to change the roll bar and suspension forks.
Thank you
Thank you
Thanks for your help
x22xhyper
Aug 15, 2009 11:48 PM
ke98248
Apr 2, 2008 05:16 PM
