Think I got a blown head gasket
Alright. Think I got a blown head gasket. I could be wrong and I pray that I am.
few weeks ago been doing doordash for some extra cash. Along the way I noticed my temp gauge would fluctuate. Now I banged on my dash and it would right back up to operating temp so I'm thinking it's a temp sensor or maybe a thermostat
Then a few times my temp gauge would go up to the middle line but not up to hot. Would go back down to operating temp when driving and I would put it in park no overheating or anything. Cooling fans are working fine
Car motor sounds healthy af in idle
And I noticed when I was driving for awhile pretty much all day my cooling resevoir was not only overflowing but boiling. The coolant sucked back into the radiator tho.
I dont know what the problem could be
I kinda doubt it's the thermostat cuz 2 years ago I change it with an OEM Honda stat for preventive maintenance along with an Aisin water pump new radiator hoses timing belt etc so I would have to worry about ANY that.
I DONT SEE COOLANT leaking on the ground or anything which kinda leads me to the head gasket.
Now if it is the head gasket. I'll take the L and do what I have to. My car still functions and drives so I'll just take it to and from work till I get another car. But help and suggestions would be great
Thanks all.
Thanks all.
Hey all I'm gonna be on vacation this week. When I get from it I'll have it taken for a compression test. Now if it is indeed the head gasket is it worth replacing? I can order the parts from a website and have my mechanic install it. Car still functions well and drives pretty good. I dont have milky oil. No coolant oil mix etc.
My symptom was that the car would cool fine under normal driving, but under any kinda spirited driving, combustion gases would leak into the cooling system (bubbling in the radiator and overflow). Oddly, mine passed a compression test fine, but i didn't have access to a leakdown test to really check it out, but by process of elimination it HAD to be the headgasket. Changed and problem solved.
If you are going to change head gasket, it is a good opportunity to take off the valve cover and change that gasket if you haven't already. Also a good idea to look around the head for any cracks or issues before mounting back up with your brand new head gasket. It may be worth getting an extra PCV valve, egr gasket, spark plug tube seals, distributor seals etc since you are already going to be in there changing things.
Good luck and happy wrenchin
92accord1988
Apr 26, 2017 08:35 AM
CptHMCrunch
Sep 13, 2013 06:29 PM
jdmboy96
18
Sep 3, 2009 08:51 PM
arielb1
Oct 26, 2004 10:38 PM
