Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
CRX, Del Sol, Civic, Integra, Prelude battery - ATX20-RS
Old Jun 29, 2021 | 03:03 PM
Antigravity Batteries's Avatar
Icon2 CRX, Del Sol, Civic, Integra, Prelude battery - ATX20-RS
Hello, fellow Honda people.
If you are still using that heavy ancient lead-acid battery in your ride, you are missing out on some huge advantages of Lithium batteries. They are super light, reliable, stronger, and and they last longer! This is not a small/lightweight battery that will keep dying on you after a few months of use, which is what smaller lead-acid batteries are notorious for.
If you have a 4 cylinder Honda without too many electronics or a power thirsty sound system, our ATX20-RS powersports battery is perfect for you! Drop some serious weight off the front end, and never worry about a dead battery again! And despite its smaller size, you will actually have more cranking power. This battery also comes with a full built-in Battery Management System, which includes cell balancing, as well as overcharge, over-discharge, thermal, and short-circuit protections, ensuring reliability and longevity. On average, our batteries last 2-3 times longer than lead-acid. Icing on the cake is our revolutionary Restart feature (built-in jump-starter), which allows you to start the car even after you accidentally drain the battery by letting it sit longer than intended or accidentally leaving your lights or one of the other accessories on. This is why the ATX20-RS is one of the only small, ultra lightweight batteries that can be used in a lot of 4 cylinder cars worry free, and we are one of the very few companies that will not reject warranty claims because you are not using a full sized, direct replacement battery. The heavy duty version (ATX20-HD) is used in many V8 cars as well.
Weight: ONLY 3.8 lbs.!
Cranking Amps: 680
For more info and a video, please click here: https://antigravitybatteries.com/pro...-oem/atx20-rs/
Mounting tray is also available: https://antigravitybatteries.com/pro...0-tray-lc-fab/
Questions? Drop a comment or send an email to info@antigravitybatteries.com
Performance
Nov 4, 2020 02:35 PM
Oct 16, 2020 08:48 AM
Performance
Jun 19, 2020 03:01 PM
thewiione
Nov 19, 2013 04:09 PM
ITRacer121
Audio / Security / Video
Dec 7, 2002 05:05 PM
