'92 Del Sol - Random restart issues after driving
Hi all,
I'm in a bit of a predicament here, my 1992 Del Sol ESI with the D16Z6 sometimes refuses to start after being driven. It will start up completely fine from cold, and then when turned off it will crank, but not start. Sometimes if I disconnect and reconnect the battery a few times, it seems to fix the issue (but not always). Could this be a failing fuel pump, or a main relay? I'm a bit lost as electrics are not my strong suit. Any help would be appreciated as I can only find topics relating to constant non-start situations.
Many thanks for your help!
James
James
JDM KILLER
Nov 21, 2009 05:52 AM
