Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Which Is Better for Your Car, Mono-tube Shocks or Twin Tube?
Old Jun 24, 2021 | 04:18 AM
MaXpeedingRods's Avatar
Default Which Is Better for Your Car, Mono-tube Shocks or Twin Tube?
Mono tube shock and twin tube shock, the only two choices on your replacement, here are a few things you should consider:
For mono-tube shock, I think Mono tube shock is designed for flat circuits, it is symbolizing no aeration cause oil and gas are completely separated, Stable damping force, larger oil capacity and no restrictions in installation angles. But it also means insufficient stroke problem, stiffer ride tends, and more friction.
But for daily driver, the ride quality is the most essential for purchasing. The twin-tube can solve all the street shock absorber problems. So, I recommend twin-tube because it is not only lower production costs and easier to maintain sufficient stroke, but also low gas pressure and friction allowing for a more comfortable ride. You never know what is lying on the surface of ordinary roads. the function of the twin-tube shock absorber remains unaffected, even if the shell case is slightly damaged.
There is not much of a difference between mono-tube and twin-tube, it ‘s not said that twin-tube is better than mono-tube, just buy what you need. MaxpeedingRods, Twin-Tube Damper Adjustable Coilover Suspension Kits, twin-Tube Structure creates a more comfortable ride. For Low Resiliency & Securing Sufficient Stroke.
https://www.maxpeedingrods.com/categ...coilovers.html
MaXpeedingRods, one of a few aftermarket auto parts manufacturers, accumulated over the years of experience of twin-tube, which offers comfortable shock absorber with excellent quality and technology, and affordable price.
GoLowDrew
Suspension & Brakes
Mar 19, 2012 09:11 AM
noobee
Suspension & Brakes
10
Apr 5, 2010 05:16 PM
skeelo
Suspension & Brakes
Nov 7, 2005 09:55 AM
thepuffyjoel
Sep 1, 2003 11:13 AM
honda93
Sep 2, 2002 03:40 AM
