A plug obd2b ecu solution for a del sol ?
Hello, I have a question.
Recently i purchased a d16y8 motor and i got the matching ecu, i also got a wiring harness but it came from a civic ex coupe (both the ecu and wiring harness are obd2. The harness is obd2b and the ecu is obd2a but I'm using an adaptor harness). The problem that I'm having is that two plugs from the engine harness connect to the adaptor harness but i don't have a connector for the a plug in the adaptor. I know that the del sol harness is a two piece design as opposed to the one piece of the civic and the civic is supposed to have the missing a plug as part of the cabin harness. Is there a way i can adapt a civic cabin harness to my del sol. Or is there a way i can get an a plug connector and wire it to my cabin harness.
Any help would be greatly appreciated.
What year is your Del Sol ? It appears that you are trying to do this the hard way.
Also, what year is the D16Y8 that you have ?
b20delslow
Jul 25, 2018 07:44 PM
stiffinEK
Nov 22, 2009 04:49 AM
