Civic 94 ECU p29 Help
Old Jun 18, 2021 | 01:33 PM
rick_21's Avatar
Default Civic 94 ECU p29 Help
hello i have a honda civic 94 EX with motor D16A9 and the ECU ODB1 p29 (37820-P29-I00-770-104526) is bad, i try to find this ECU but i had no luck, my question is if is posible to use another ODB1 ecu that is compatible ( ex. p28, p06 ) that will make the engine work fine with no problems.
and thank you for your help.
Old Jun 19, 2021 | 07:12 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Civic 94 ECU p29 Help
Those questions are challenging to answer. There isn't a lot of information regarding foreign ECU's and Engines.
One thing you will need to be wary of when trying other country ECU's is whether or not you have an Electronic Load Detector or not. Some countries did and some did not. The ECU will either want one or not depending.
Old Jun 22, 2021 | 10:35 AM
rick_21's Avatar
Thank you TomCat39, i check the under the hood fuse/relay box and the honda manual an it has no ELD Electronic Load Detector for this engine.
Old Jun 22, 2021 | 02:06 PM
Chrisfrom1986's Avatar
You would have to use a modified obd1 ecu (p28, p06 or p75) with the stock p29 map programmed to it.
John Bennett
Feb 1, 2013 03:00 PM
Nino_eg6
11
Jun 17, 2008 07:26 PM
bmiller17
Jan 20, 2006 08:16 PM
xwade01
Mar 8, 2005 07:48 PM
