Honda CR-V & Element 2WD & 4WD Element & CR-V
2005 Honda CRV
Old Jun 17, 2021 | 07:25 AM
SassieCassie's Avatar
Icon4 2005 Honda CRV
Driver's door lock won't work with auto lock and can't be pushed down manually either, whether door open or closed. You can see it figit a bit when you hit the lock remote, but it won't budge.
Old Jun 17, 2021 | 10:46 AM
brownbeardad's Avatar
Default Re: 2005 Honda CRV
I just sold my 2006 CRV EX AWD. This CRV has a recall on the power door lock and window controls. It was replaced on my CRV but I never had any issues with it. The recall was in response to to reported electrical fires originating from this control unit. If your control unit is covered by this recall and faulty, the dealership should replace it. If you want to check the fuse, this would be an easy first step. The under-hood fuse box is located in the engine compartment on the driver’s side. Fuse location is number 16.
Primary box
Joey Lopez
Apr 24, 2019 09:57 AM
klerbman
Feb 2, 2019 07:45 AM
dsgisme
Jun 4, 2018 07:14 AM
