03 accord radiator cap failure. Could this be signs of a bigger issue?
Old Jun 16, 2021 | 01:29 PM
AaronAccord's Avatar
Default 03 accord radiator cap failure. Could this be signs of a bigger issue?
03 accord radiator cap has failed twice and I'm looking to see if it is a bigger unadressed problem that I'm having.
Old Jun 16, 2021 | 06:26 PM
TheShodan's Avatar
Moderator
Default re: 03 accord radiator cap failure. Could this be signs of a bigger issue?
Start from the beginning with your issue and what you've done so far. Please don't make us guess what you're asking... Spit it out, sir.
Old Jun 17, 2021 | 06:35 AM
Default Re: 03 accord radiator cap failure. Could this be signs of a bigger issue?
The spring on my radiator cap snapped off. I replaced it and refilled my radiator. The spring assembly snapped off again. I've ordered another one, but I'm unsure if there us a bigger issue.
I Thought that I was clear enough in the first post, clearly not.
Old Jun 17, 2021 | 10:31 AM
Sic_DA_Nine's Avatar
your first post stated that it failed not broke.
did you use a oem part?
TOO MUCH TORQUE
Jan 25, 2012 10:09 PM
Cor-el
Apr 26, 2007 04:15 PM
