Hatchback and sedan upper control arms
Old Jun 16, 2021 | 07:06 AM
brorgaben's Avatar
Default Hatchback and sedan upper control arms
Is there a difference between the hatchback and sedan upper control arms. I'm asking because I've got a loose uca balljoint on the right side which needs to be fixed before getting alignment and I'm only able to find an uca from a sedan. Also should I replace both sides or is that not necessary/no need for alignment after replacing?
Old Jun 16, 2021 | 10:12 AM
Tyson's Avatar
Default Re: Hatchback and sedan upper control arms
same.
earlier EF's had a welded balljoint in the upper arms, later arms had a circlip that made it replaceable using aftermarket balljoints.
its obvious if you just look if its welded. the welded joints are also a bit taller, reducing clearance, fwiw.
Old Jun 16, 2021 | 10:51 AM
brorgaben's Avatar
Thanks
FixItOrWreckIt
Apr 25, 2020 06:08 PM
702SI
Suspension & Brakes
May 12, 2017 07:00 AM
Kitsune
Apr 10, 2013 11:55 PM
janz3n
Mar 14, 2007 03:49 PM
