D16z6 piston ring gap for boost
Old Jun 14, 2021 | 01:55 PM
Alexdelsol93's Avatar
Default D16z6 piston ring gap for boost
I've read a bunch of information about piston ring gaps for boosting and settled on .18 for top ring and .20 for bottom ring. My issue is i bought Hasting piston rings and was shocked that the top rings were .20 right out of the box without grinding them down. I even called Hasting to see if it was a mistake but the only quality control the rings from .10-.20 range. So should I just work with the top ring gap at .20 and then gap the 2nd rings to .21/ .22? or just order another box and hope that i can get to the gap tightness that I want??
Old Jun 14, 2021 | 09:10 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: D16z6 piston ring gap for boost
.020" on the top ring will be fine. Go to .022" on the second ring and run some boost. You will be just fine.
Boyle.R
Jun 21, 2014 12:38 AM
97grnrs
Feb 8, 2007 11:22 AM
Wheelman-CZ
Feb 5, 2007 08:44 AM
