Crank Positition Sensor Placement J35Z5
Can anyone confirm a change in the install location of the CKP sensor for the J35Z5 motor?
Here's what I think I know: Up until 2009 the crank sensosor was installed on the right side of the motor with all of the timing/cam assembly. It looks like a plastic part that fits next to the crank gear and the sub harness went underneath the gear and and came out near the oil pressure solenoid(s).
I'm pretty confident that I already installed the CKP on the motor sitting in my garage and its location is off the oil pan. I am building the new motor for a 2010 Ridgeline, but because the model years run from 2009-2014 there doesn't seem to be much information confirming a change in the install location from 2009 to 2010. I don't see why there would be two crank position sensors, but........
This is my first time putting this motor together and I would really appreciate a heads up.
2009 and 2010 are the same for the CKP sensor location.
See your other thread: https://honda-tech.com/forums/all-mo.../#post52434811
twinj
10
Apr 19, 2007 07:18 AM
