del sol injectors and civic injectors
Is there a difference between these 2 injectors? I had a bad injectory and I found a del sol with that was wrecked so I took the injectors from it and threw them in the civic. This was I believe a 93 del sol with a d series engine. So is there a difference because the injectors had different writing on them so I didn't know if they were the same or not...but they work great
DEF
DEF
Del Sols come with D16Z6, D15B7, and B16A3 engines.
Just make sure you have the same engine that you are taking the injectors from and you will be fine.
The engine code is on the block to the immediate right of the tranny to the left of the header.
all honda acura injectors are the same flow/size from d series to b series engines. i think the number is 260cc and injectors in h22/23 preludes are larger 310cc.
Thank you for clearing that up for me the del sol at junk injectors say japan and mine i believe said usdm so I didn't know if there was a difference...thanks again see we all learned something.
DEF
DEF
