Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 Honda Civic hybrid problem
Old Jun 11, 2021 | 08:02 PM
JettA1's Avatar
Default 2006 Honda Civic hybrid problem
I have a 2006 Civic 1.3L and recently the IMA light and the check engine light plus brake system warning lights came on and then the gear won't shift from park, after sitting for a while it starts but this keeps occurring. The error I get from my portable Scanner I am getting P16d6 and at intervals it comes with P060a, P16d5, C1555 and U0100. Please has anyone had this issue too?
Old Jun 11, 2021 | 08:37 PM
Ryanthegreat1's Avatar
Default Re: 2006 Honda Civic hybrid problem
https://honda-tech.com/forums/honda-...blems-3256085/
More than likely a failed PCM.
Old Jun 12, 2021 | 02:52 PM
JettA1's Avatar
Originally Posted by Ryanthegreat1
Thank you for the response. I got a used ECM and will hopefully get it reprogrammed tomorrow, that is the same as PCM right?
Old Jun 12, 2021 | 06:54 PM
Yeah, typically in Honda speak PCM means automatic transmission as powertrain control includes the transmission. Manual transmissions are usually ECU as only the engine is controlled. Semantics really.
Old Jun 14, 2021 | 08:08 AM
JettA1's Avatar
Okay thank you so much.
So I ordered the part on ebay but what I got wasn't what I was expecting, the attached photo is what I got and I don't think it is the right thing?
ECM should be the one under the hood by the battery and coolant overflow from my understanding
Old Jun 14, 2021 | 09:05 AM
Probably correct? What is the part number on it? Should have a sticker.
Old Jun 14, 2021 | 11:02 AM
JettA1's Avatar
This is the part I got from ebay
But this is the ECM under the hood of the vehicle
Old Jun 14, 2021 | 11:07 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Yep, wrong part.
Old Jul 2, 2021 | 12:55 PM
JettA1's Avatar
So I got an ECM from ebay and had it reprogrammed to the the vehicle and it started alright but the battery and IMA lights are on and the IMA seems not to be working i.e. charging or discharging, nothing shows on the guage as shown in the picture before. The technician says it is a hard code and can't clear.
Please does anyone know what the issue could be now? I would appreciate your help.
Old Jan 26, 2024 | 08:15 AM
Gojo-jm's Avatar
Did you ever find the problem and solution? I have a 2006 civic hybrid and I have the same problem with codes U1205, U0110 and B1152 and B2990
MS007
Honda Civic (2001 - 2005)
Jul 12, 2017 02:52 AM
strykrol
Aug 19, 2014 02:55 PM
adueisaac
Transmission & Drivetrain
Mar 6, 2014 08:04 PM
