can somebody please tell me where the two prong connector by the positive battery terminal attach to? Are they ground? Please see the attached pictures. They inside the black rubber housing below the main battery terminal. Thank you 😊
Someone added an aftermarket inline blade fuse holder with wire. There is an aftermarket ring terminal stud with the blue plastic that is part of that wire connection further up in your photo.
They were using it to draw power for something, directly from the battery.
You probably could just leave it. But, if you're curious, you to could try to follow where the other end leads to see if it still connects to something.
