Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2013 Honda Accord Sport won't shift out of Park
Old Jun 8, 2021 | 06:05 PM
SHANEW's Avatar
Default 2013 Honda Accord Sport won't shift out of Park
Hello,
New member, first post. I have a 2013 Honda Accord Sport and last Saturday morning, without warning, the car will not shift out of park, and the display does not show a "P" for being in park. Checked all fuses and they are all good. I replaced the shift interlock solenoid and still no change. Checked all the fuses again and they are all good. Checked the brake light switch and it checks out good but have not replaced it. I can push the shift lock release and change gears and the R, N, D and S shows on the display but once back in park the P still does not display and the key does not release until unhooking the battery. Anyone have similar issues or have suggestions I would be happy to hear. Thank you!
Old Jun 8, 2021 | 06:36 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2013 Honda Accord Sport won't shift out of Park
Take a look at the harness wire and connector to the Transmission Range Switch (circled). One possibility is that the blue wire for the Park position that goes from the switch connector to the PCM may be damaged by rodent chew.
Old Jun 9, 2021 | 02:39 PM
SHANEW's Avatar
Thank you! I will check it out.
Old Jun 9, 2021 | 06:13 PM
SHANEW's Avatar
Thanks for the suggestion, you were right! Blue wire is missing a whole section and the black wire is almost chewed in half. Pesky varmints!
Old Jun 9, 2021 | 06:41 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The black wire is the ground source to the transmission range switch. The blue wire is the Park position wire. Probably have to splice in new wiring to repair the damaged wires.
Old Jun 9, 2021 | 06:47 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Honda sells rodent tape (treated with pepper capsaicin ) since rodents sometimes like chewing on the wires and even the connectors.
https://www.collegehillshonda.com/pr...4019-2317.html
Jlm_93accordlx
Aug 22, 2017 05:36 PM
jefff1964
Aug 5, 2017 06:15 AM
blurry454
Jun 22, 2009 06:36 PM
