Not a main relay lol
Hi I have a 91 crx si it sat for 7 years after my uncle passed away I got it pulled everything off the shell and swapped it to a rust free roller due to the si being rotted beyond repair so It will start and die it is not loosing spark from the ignition the injectors are firing I have 190 psi across the board and i have dropped the tank and cleaned the fuel lines iv replaced plugs wires distributor and fuel filter any ideas ? I can bairly keep it running pumping the gas real fast. And there is zero codes
I did buy this i brleive p28 ecu from a guy in grand rapids michigan that claimed he worked for honda its chipped and has a data log cable hook up and everything but that 2 has been sitting atleast 5 years now all have to open it up
roofracks91
Sep 16, 2012 02:49 PM
sidewayz32
Apr 10, 2006 09:18 PM
indy_parrothead
May 5, 2003 11:15 AM
