2000 EM1 Stock Motor / Tranny P0172 Requesting Help
Old May 27, 2021 | 03:35 AM
Andy099's Avatar
Default 2000 EM1 Stock Motor / Tranny P0172 Requesting Help
Schedule to fly out to pick up an EM1 today
Anyone fix CEL P0172 Too Rich
Seller Cleared the CEL by putting in
JDM P30 OBD-1 ECU with Jumper Harness
Runs Smooth no CEL
Did some research and could be a few things, O2 Sensor is a common issue
Below is some information i found.
Any help is appreciated esp before i fly out 😂
“Problem is, P0172 is a rich code.
Long term fuel trim had to exceed -16% (0.84) to set P0172.
Those engines had issues with the primary sensor going "numb" for periods of time, long enough for the computer to go nuts with fuel delivery but sometimes not long enough to code for a sensor problem.
If the primary O2 gets stuck at a high voltage (rich value), the computer pulls trims down trying to get the desired response from the sensor, but since the sensor is stuck it can't respond. The computer has the ability to add or subtract enough fuel to bog the engine.
Then when the sensor starts working again or the computer defaults to open loop again, the bad running suddenly stops.
THAT'S why I said to unplug the primary sensor and drive it a while first, back in post 3.
Cam timing, tight valves, inaccurate MAP reading, wrong injectors, and more could cause a rich code too”
JDM_EH2
Oct 20, 2005 11:49 AM
alberto.garrido
Jul 27, 2004 09:33 AM
DropSquadCivic
May 17, 2004 07:25 PM
DumpedSi
Aug 21, 2003 05:57 PM
