H23 Vtec timing belt slight "walk off"
Old May 25, 2021 | 05:26 PM
Nathan007's Avatar
Default H23 Vtec timing belt slight "walk off"
Hey gang, been a long time!
After replacing my belt due to failing cam seals, I noticed it's slightly off the cams. Very slightly. I dit not really notice when i took it off originally, so I have no real reference.
I am running a KS manual tensionner, for a long time now. I adjusted the best I could between not too tight and not too loose (depending on the "stroke", it will be tight or average"). While turning the crank by hand I never noticed it. I ran the engine for about 30 min varying RPM range, from idle to about 5k rpm. You can see the belt it not overly tight, but not too loose as to slam everywhere.
I measured the portion of the belt hanging out from the cam, could only check exhaust since the way the engine fits, I have .025" of belt out. It did not change.
For the moment I plan to run it as-is, and periodically cheking the belt.
You guys think it's safe? I need to get the car running ASAP (other projects to finish , god damn I hate being an full-of-responsabilities-no-time-to-spare-adult lol)
Old May 25, 2021 | 08:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: H23 Vtec timing belt slight "walk off"
Nope. You got something loose or crooked. Double check your install.
Old May 28, 2021 | 04:51 PM
Nathan007's Avatar
Well, I rechecked everything, and for sure will not remove the waterpump since the engine is full of new coolant. Did not find anything out of alignment
I did loosen the belt, and after running until warmup the belt is definitely not off the cam gears in the top section (valve cover on, checked with inspection camera) and by measuring about 1/2" lower from the valve cover lower surface, the belt "out" measurement is maxed at .010".
I will run it like this keeping an eye out periodically and measuring to make sure it stays there.
Old May 28, 2021 | 10:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
You stated a measured amount of timing belt sticking out past the front side of the cam gear was .010"... as in .25mm... correct ?
The picture above appears to be much greater than this.
kornerk12
Nov 25, 2007 02:03 PM
hyabusa hunter
Feb 17, 2007 07:59 PM
h22aseemsgood
Nov 14, 2006 06:53 PM
flip1199
Apr 4, 2005 08:57 AM
