2003 civic high rpms
Old May 25, 2021 | 11:12 AM
David ensenada's Avatar
Default 2003 civic high rpms
In a bumper to bumper traffic the rpms start going above 1000 rpms up to 3000 rpms. The only codes the scanner shows are for the egr valve and canister. In a normal traffic my car works perfect. Can some one give me a clue?
my car is manual transmission and with the clutch I control the rpms , but I am burning my clutch.
Last edited by David ensenada; May 25, 2021 at 11:22 AM. Reason: Forgot to mention my car is manual transmission
Old May 25, 2021 | 12:08 PM
Full_Tilt's Avatar
Default Re: 2003 civic high rpms
1. Do not use your clutch to bring the RPMs down. Thats dumb.
2. SInce you have a code for evap, Id be inclined to think it was involved in some way. You may want to try unplugging it and see if it changes anything. You may also be having an issue with the IACV. Google "honda-tech how to clean IAC valve".
Old May 25, 2021 | 03:29 PM
Thank you for your advice.
mdbrum
Honda Fit
Apr 25, 2018 12:23 AM
chasenpaper
Honda Civic (2006 - 2015)
Jul 10, 2010 10:19 AM
jdmCivic925
Oct 7, 2004 05:27 AM
wm5holla
Mar 19, 2003 11:18 AM
