Hey guys so I’m having an issue with my motor mount. I had to replace the starter already three times within two years I also had to replace my flex pipe three times within two years. This is becoming a huge issue and all I can think the problem is is both motor mounts. But from looking at them the rear one looks as if it’s broken but I’m not sure if it’s supposed to be bent like this. Here’s some pictures what do you guys suggest also I’m going to try to attach a video. Thank you for your help if you look close pass the power steering pump you can see them out it looks as if it’s bent but I’m not sure if it’s supposed to be bent. If both mounts are gone if I can only replace one which one should I replace first it feels as if the rears more effected
but I’m not sure
