ABS, TC & Brake lights on, help
I have a 2012 honda accord (4 cyc) here that runs and drives fine. It has an intermittent issue where the brake, ABS and traction control light comes on and I can't figure out why. It has no codes and brake fluid is full. The lights than go off randomly. Here Pic of codes and dash lights.
If you haven't done so already, you might want to update any applicable software on the code reader. Not all code readers can read Honda ABS codes if they don't have the applicable software.
Replaced the battery with a new one last light and the ABS lights returned intermittently.
Hasn't returned today, can it be the alternator overcharging the battery and causing the lights to come on ?
NABATE79 were you able to ever figure out this issue? I am having the exact same lights coming on my dash. Any help is much appreciated.
I do show some corrosion on my battery terminals/connections. But looks like that didn't solve your problem. Thank you!
Yes i did.
Yes i ended up having a mechanic pick up a used ABS module from the scarp yard and install in my car.
It ended up being a couple hundred dollars and has been working great for well over 1 year now.
Netas Smith
Feb 27, 2020 01:14 PM
IncaEM2
Honda Civic (2001 - 2005)
Oct 15, 2007 02:57 PM
da6er
Feb 11, 2005 06:05 PM
