Water Pipe Replacement
Old May 18, 2021 | 08:04 PM
Stock95delsol's Avatar
Default Water Pipe Replacement
ok, i've decided that i should change the corroded water pipe on my B16A while i have the thermostat housing off
but it's stuck in there probably from corrosion because the car sat for years with tap water in the cooling system.
do i just have to pull hard on that pipe to get it out or is there something else holding it on? i tried pulling but don't
want to break something that i can't easily fix.
thanks!
Old May 18, 2021 | 09:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Water Pipe Replacement
Yes, pull hard. A slight twisting motion back and forth should help too while you are pulling.
Old May 18, 2021 | 09:49 PM
that's what i tried but i'll pull and twist even harder. is it possible to get a new pipe back on without dropping the intake manifold?
Old May 19, 2021 | 05:43 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
It's honestly easier to deal with when the motor is outside the car and the manifold is off. You can then get decent leverage and power in your wiggle pull. It's also a lot easier to clean the hole the pipe goes into.
I'm sure you can do it with the motor in the car but it's going to be a lot more challenging. And it will be even more challenging doing it with the manifold in place. That is my opinion based on the one time I pulled that pipe, but mine was on a D series. YMMV
Old May 19, 2021 | 05:59 AM
yes, i understand that but i just wanted to know if it can be done without removing the engine or takin the intake off.
thanks
Old May 19, 2021 | 08:17 AM
muellersfan's Avatar
Have you considered the possibility that the engine is not worth saving due to severe internal corrosion caused by tap water and time?
Old May 19, 2021 | 10:25 AM
I got it running very well or wouldn't be doing all this work.
Old May 19, 2021 | 07:37 PM
OK, i got the water pipe out but i had to use a pry-bar on the tang because it was STUCK.
After removing i was glad that i decided to replace it because it's very corroded.
the problem now is that i'm not sure what year Integra this motor came from
and it's a JDM . I THINK that it's an 1989, 1.6 but i don't want to order the wrong pipe.
any help identifying this thing would be greatly appreciated.
for some reason my images won't upload.....
Ainsworth03
Honda Civic (2006 - 2015)
Jun 27, 2014 12:56 AM
GoSickemRobert
Mar 28, 2011 07:19 AM
NZstan
Apr 16, 2010 09:15 PM
91AccordSE
Sep 8, 2004 05:44 PM
kraig
Jun 6, 2004 12:32 PM
