Honda CR-V & Element 2WD & 4WD Element & CR-V
2016 CRV EX AWD Rear Brake Slide Pins
Old May 18, 2021 | 04:07 PM
brownbeardad's Avatar
Default 2016 CRV EX AWD Rear Brake Slide Pins
I am replacing the front and rear brakes on this CRV. The top and bottom rear slide pins are different. One pin is round and the other has three flats. Also on my CRV the left and right side brake slide pins are reversed. Since the dealer did not re-install the slide pins the same on both sides, I can't determine which goes where.
I understand from other forums the slide pin with the flats may go on the top to porvide for rotating the caliper. So I request which slide pin, round or with flats goes to the top and bottom. Any help in identifying pin locations will be appreciated.
Old May 18, 2021 | 04:18 PM
starchland's Avatar
Default Re: 2016 CRV EX AWD Rear Brake Slide Pins
Check any parts catalogue available online and if that doesn’t show it in detail, google the part# and find a photo for reference
Old May 18, 2021 | 04:23 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Old May 19, 2021 | 05:43 AM
Thanks starchland and tech8. I did spend about two hours yesterday looking for a photo. Found one photo of the bag. The parts diagram provided is much more detailed than the diagrams I found. So going with flats on top. I appreciate your quick response.
LsDecepticon
Mar 7, 2016 01:26 AM
xxpaulcpxx
Honda Civic (2006 - 2015)
Jul 25, 2010 11:12 PM
Si_Allen
Jan 10, 2007 02:07 PM
Solscud007
May 27, 2004 07:39 PM
Ef Whore
Nov 20, 2002 01:32 PM
