H22a.. Part needed for build?
Old May 17, 2021 | 08:30 PM
jose david cruZ's Avatar
Default H22a.. Part needed for build?
So I recently got a h22a closed deck block from my friend. I want to build it and run it in my 98 accord so far I know I need the oil pump from an h22a4 to keep it obd2 and I can use the crank shaft sprocket on my f23a so I’m pretty set for the bottom block.. he also gave me the intake manifold for it and it seems to be obd2 I’m just missing the head and I don’t know witch one I would have to get so I can fit everything and make it obd2.. any info will help I just want to have my parts list done so I can start building it
Old May 17, 2021 | 11:06 PM
Kenneth Frazee's Avatar
Default Re: H22a.. Part needed for build?
OBD1 is really easy if u can get ecu adapter from wry wire or whatever. The sensors around your obd2 crankshaft are all contained in obd1 h22 distributor
myaccord1993
Oct 24, 2016 04:44 PM
cgaleema
Apr 28, 2011 06:51 AM
neon_ice7
Aug 14, 2008 01:35 PM
JBirch_97Prelude
Feb 20, 2007 12:13 PM
JBirch_97Prelude
Feb 19, 2007 07:15 PM
