Curious about open plugs on B16a block.
Old May 17, 2021 | 04:46 PM
99 si dan's Avatar
Default Curious about open plugs on B16a block.
Hello, I
am currently building a b16a for boost. There are two holes in the back of the block a threaded hole and a smooth hole, I am wondering if I just get a frost plug for the smooth hole and a threaded plug for the threaded hole will I build to much Positive crankcase pressure?
Old May 17, 2021 | 04:57 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Curious about open plugs on B16a block.
You'll need something like this, if you want to run a CC setup. Note, you will need to remove another threaded fitting on the other side of the oil filter location
Genuine OEM Honda B-Series Oil Catch Can Installation Joint Fitting Hardware Kit | eBay
ej1_civic
Oct 19, 2011 10:53 AM
EkayKid
Dec 9, 2008 10:15 AM
AMS MIKE
Aug 4, 2007 07:20 AM
