Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2009 Civic LX, AC leak in evaporator core
Old May 17, 2021 | 07:23 AM
macasoft's Avatar
Default 2009 Civic LX, AC leak in evaporator core
System does not hold the vacuum. Charged a bit with UV dye and the UV dye is dripping out at the bottom at the AC drain tube. Just to be sure, I thought (after checking there is no pressure in the lines) that I close down the AC lines after the low and high pressure points with some plugs like this:
https://www.stainlesssteelfittings.c...inless_p/p.htm
That way if I make vacuum again and it holds it, I can be absolutely sure it is the evaporator only.
What size plugs I should get? Is there same parts already for it? I could not find.
EDIT: I was thinking something like these:
https://www.homedepot.com/b/Hardware...s/N-5yc1vZc2cw
Thank you in advance!
PS: Once the lines gets some charge, the compressor kicks in, clutch is engaged, and there is no UV dye (UV light) or freon escaping (sniffer tool) anywhere else, I checked.
Old May 20, 2021 | 03:27 AM
macasoft's Avatar
Default Re: 2009 Civic LX, AC leak in evaporator core
Anybody? This weekend I will get all sizes from Home Depot and try myself if no answer
samson_420
May 20, 2021 03:29 AM
Beau Gotti
Sep 20, 2006 02:21 PM
marcusteg
Jul 21, 2005 12:55 AM
