Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
C101 Plug/Grip pinouts Civic Si 8th Gen
Old May 15, 2021 | 05:41 PM
deltoid61's Avatar
Post C101 Plug/Grip pinouts Civic Si 8th Gen
While doing K-Swap i needed this but all i could find out was older cars,like delsol,Eg,EK.
So i sorted it out myself.
This is part of my K-swap build series guide in CRZ/Fit using Civic Si PCM/ECU.
Its in episode 14.it also shows how to figure them out if you dont find any diagrams online.
For those who are here for only pinouts only.
07:42 of Civic 8th gen C101 Plug Neat
13:11 C124 of Honda CRZ Zf1 Neat
The latest will be in my dropbox folder.You can download and save them.
Folder also contains other ECU pinouts of Civic Si, CRZ, Fit.
Folder
Old Nov 27, 2023 | 06:32 PM
Pat_918's Avatar
Default Re: C101 Plug/Grip pinouts Civic Si 8th Gen
Part 14: K-Swap Guide CRZ/Fit
Folder
Assalamualaikum,
I need some help with my swap. I have a Japanese FD1 with the R18 engine and it is automatic. I have swapped the R18 engine with a USA K20Z3 with a Manual transmission.
The C101 plug from the K20Z3 has different wires and pin locations to the R18. I have taken notes and uploaded it here. I need to know which wires I have to repin between the male and female ends of the C101 plug.
This is not the same as the diagram that VTEC Academy did for the C101 Conversion because their car was already a manual and the new engine was manual. My car is an automatic that we are converting to a manual with the K20Z3 engine.
File Type: pdf
File Type: pdf
Craigc187
Mar 28, 2019 04:00 PM
richiejr416
Jul 22, 2012 12:44 PM
