Honda CR-V & Element 2WD & 4WD Element & CR-V
2004 CRV Shudders when going up hill only at about 2800 RPM
Old May 13, 2021 | 11:29 PM
JeffGuldenschuh's Avatar
Default 2004 CRV Shudders when going up hill only at about 2800 RPM
Have a 2004 CRV that the engine shudders and cuts in and out only at about 2800 RPM going up hills. Doesn't do it at any other RPM below that or even at that RPM on flat road.
Has a P1457 EVAP code and a second code that just says N/A.
Any thoughts?
Old May 14, 2021 | 07:29 AM
Davey7847's Avatar
Default Re: 2004 CRV Shudders when going up hill only at about 2800 RPM
Any thoughts?
Assuming its not a misfire ( no misfire codes) its possible the torque converter clutch is chattering ( slipping on partial engagement) . Try a drain and refill of the trans oil. If its contaminated you may have to repeat the drain and refill 3 times.
Old May 14, 2021 | 08:19 AM
starchland's Avatar
What code reader is it? Does it do it as well in d3?
Old May 16, 2021 | 06:31 AM
Joshua Smith's Avatar
I had an issue with mine where something called the "knock sensor" had gone bad. It was causing me to shudder and lose power going uphill, almost rolling backwards on mountain roads. Might be worth a check. Pretty cheap and easy to take off but requires a rather large socket.
jordan_rael
Feb 3, 2010 02:54 PM
stickman78114
17
Feb 2, 2010 01:12 AM
Fatty_1775
Jul 25, 2003 04:52 PM
