Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
How to Set The Preload Tension
Old May 13, 2021 | 06:57 PM
MaXpeedingRods's Avatar
Default How to Set The Preload Tension
When you install a new set of coilover, you need to adjust the preload tension. We've been asked many times "How should I adjust the preload tension for daily use?"
Here is a video to comprehensively teach you to set the proper preload tension. Check this video below.
