Assistance Needed: Car will not start due to relay, battery or alternator. Discuss?
Old May 13, 2021 | 05:42 PM
White94coupeEg's Avatar
Default Assistance Needed: Car will not start due to relay, battery or alternator. Discuss?
I have a 94 coupe with a B20v in it so i had to get a battery for it. So once that was done the car started fine was running strong so i let it run for about 30 min. then i decided to move it once i can pushed the clutch pedal it was a little hard so i gave it some more pushing power once it actually did like it was supposed to do the damn car cut off. so i tried to re start it and nothing is happen the only thing come on when turning the key is battery and srs light. so no check engine light or oil light is on. and no i dont hear the fuel pump priming. i have notice the main relay aint clicking but its making a [size=13px]weird[/size] [size=13px]noise. i have change out relay and tried another ecu. all fuses are good. so what else could it be i been fighting this for a week now. please help!!![/size]
Old Jun 23, 2021 | 09:55 AM
Hondakuz's Avatar
Default re: Assistance Needed: Car will not start due to relay, battery or alternator. Discuss?
Have you checked the alternator? That could give you problems, as well as your starter. Or, it could be a bad battery cable… Hopefully something easy to fix and not too expensive!
stevenjr
Feb 3, 2013 03:29 PM
Jap_Spec_Imports
Sep 24, 2006 11:16 AM
all_motoref9
May 27, 2004 12:57 PM
jondancer
Apr 24, 2004 09:39 AM
