EG6 Yellow Interior Check
The give away is the back side of the door card. You can't redo that bit properly without removing the panel for the door card. And there is no way to do that without leaving damning evidence of the work. Factory melts the posts together. To remelt is obvious or usually people use screws and washers after they either melted them off or cut them off.
