Code 22 vtec pressure switch
Old May 9, 2021 | 06:42 PM
B16A_EG's Avatar
Default Code 22 vtec pressure switch
Hello, I’ve got a 93 civic hatch with a b16A (p30/pr3-1) swapped into it. It’s obd1.Not sure what ecu I’ve got in it, but I got the code 22 the other day. I’ve read that the usdm b16’s have a switch but the jdm b16’s don’t, is this true? If so, does bypassing the vtec pressure switch work on all the “p” series ecu’s or does it just work on certain ecus (p30, p28, etc)? I’ve read this http://www.phearable.net/tech/wiring/vtpsbypass.gif, but I’m still a tad bit confused.
thanks in advance!
Old May 11, 2021 | 03:42 PM
egsleepercivic's Avatar
Default Re: Code 22 vtec pressure switch
obd1 JDM B16a had the pressure switch, take a pic of the vtec solenoid if you are not sure
Old May 11, 2021 | 08:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I haven't seen any JDM B16A's with a VTEC Pressure switch... they are either capped/plugged with a bolt or the housing itself isn't drilled for such a device.
Old May 12, 2021 | 07:08 PM
Obd1 jdm p30 will throw a code for it, at least in my experience with my motor
I got my b16a and jdm p30 back in 2003 from hmotorsonline, came with the pressure switch on the motor and will throw code if unplugged
Old May 12, 2021 | 09:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Very interesting... thank you for sharing your experience.
prime-R
16
Apr 11, 2009 05:33 PM
spyderracing
15
Oct 21, 2004 05:49 PM
Blake97GSR
Nov 7, 2003 06:01 AM
Lysawy
Nov 4, 2002 11:32 PM
