Hello
The contacts in my 7-way connector got corroded. I guess that's what you get when taking jetski to the salt water all the time.
I want to replace the connector assembly, but could not find a source for it. Looks like it only sold with the whole wiring kit. I dont need the whole kit, only connector. Is it possible to find just it or is the only option is buying the whole kit?
It appears you are correct. If you want a replacement without buying the wiring, you'll have to source a used one from a wrecker. Everything else is universal aftermarket plugs.
Does it have a part number on it anywhere that you can use to search on eBay?
