Where can I find rubber engine mount replacements??
1997 Honda Civic del sol
Engine B1a62, Manual transmission, 107k
1.6L DOHC 16 Valve VTEC
I've had my engine mounts inspected and the rubber insulation needs replacement. Here are a couple photos: https://photos.app.goo.gl/2WMC9uSr3YEi7xPs8. There's only two photos, but I'd like to replace all of them since they're probably the original ones made over 20 years ago.
I've tried to find OEM replacement parts for my mechanic on this website,
https://www.oemhondapartsonline.com/...engine-mount-1
But the parts seem to be discontinued. Here's a part list for reference:
Rubber, Transmission Mounting (Mt) - Honda (50803-SR3-A01)
Rubber, Rear Engine Mounting Insulator (Mt) - Honda (50810-SR3-030)
Rubber Assembly, Engine Side Mounting (Hydro) - Honda (50820-SR3-J11)
Rubber, R Front Stopper Insulator (Mt) - Honda (50841-SR3-N10)
Rubber, L Front Stopper Insulator (Mt) - Honda (50842-SR3-N10)
Does any one know where I can get quality interchange parts??? Please let me know if the list I provided is inaccurate or incomplete.
I've found a possible link, but am not sure about this seller:
https://www.partsgeek.com/gbproducts...SABEgJTKPD_BwE
Thoughts?
Thanks!
-T
Thoughts?
Thanks!
-T
here are oem replacements that are still available
www.hondaautomotiveparts.com
i was unable to find a driver side engine mount. what you can do is get an integra 3 bolt block bracket for the timing side and use an integra mount
www.acuraautomotiveparts.org
Rubber, Transmission Mounting (Mt) - Honda (50805-SR3-010)
Rubber, R Front Stopper Insulator (Mt) - Honda (50841-SR3-030)
those 4 mounts are still available from honda at the above site listedi was unable to find a driver side engine mount. what you can do is get an integra 3 bolt block bracket for the timing side and use an integra mount
Rubber Assembly, Engine Side Mounting (Hyd) - Acura (50820-ST7-003)
