what front sway bar
just curious to what front sway bar you folks think I should change to, if any.
current setup: ITR Front and Rear LCA's with ITR front & Rear sway bars. ITR shocks w/neuspeed sport springs...might be changing to itr spoon springs.
Currently the car will push/understeer under very hard/sharp corners, but in fast swooping corners its almost perfect... I was thinking maybe the 92-95 si/ex frong sway to help the cornering during sharp turns like during an autox.
[Modified by S&P500ITR, 8:26 PM 11/16/2002]
FWIW, I have an ITR rear bar and a 21mm front bar from a DelSol, and I Like the setup for autox. Stock bars can usually be had betty cheap. You could probably pick up a stock 21mm or 22mm bar for $30 or $40. For such a low price, you could get both and just experiment to see what you like.
