Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Where is the Fuel Tank Pressure Sensor located on a 4 cyl accord?
Old May 4, 2021 | 06:32 PM
LSteggyguy's Avatar
Default Where is the Fuel Tank Pressure Sensor located on a 4 cyl accord?
I have a 2003 accord with the K24A4, I suspect the FTP sensor is bad and I'm looking to replace it. Where is it located? I'd assume either on top of the fuel tank or somewhere in the engine bay? Or perhaps on a charcoal canister under the vehicle?
Old May 4, 2021 | 07:19 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Where is the Fuel Tank Pressure Sensor located on a 4 cyl accord?
It's on the EVAP canister under the car.
Old May 5, 2021 | 04:01 PM
LSteggyguy's Avatar
Found it, just like you described. Do you know what the vacuum line attached to the sensor is for? Is it a reference for atmospheric pressure, taken from inside the cabin?
Also, do you know if the evap canister vent shut valve is a replaceable part? It looked pretty integrated to the canister to me, but maybe I didn't understand how the unit was put together.
Old May 5, 2021 | 04:58 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
1. The air hose connected to the FTP sensor is a vent tube that goes to a vent joint.
2. The vent shut valve is replaceable. This shows the replacement for Non-SULEV models. SULEV models are different.
Old May 5, 2021 | 08:08 PM
LSteggyguy's Avatar
Perfect, that's exactly the info I needed. Thanks
Hopefully I won't need to replace that vent valve, but I'm waiting on the evap system monitor to set to ready or to fail so I can see if my initial repair worked.
Old May 7, 2021 | 12:18 PM
LSteggyguy's Avatar
How does the canister vent shut valve work? I removed mine and checked the resistance across the 2 pins and it came out to 20-ish ohms. I applied 12v and ground to the pins to see if I could hear the valve shut and open, but the wires got red hot and now the 2 pins only have .2 ohms across them. I'm guessing I fried something inside, but why and how? I thought it would work on 12v like everything else on the vehicle.
osageit
Jun 24, 2024 01:21 PM
Omar Storr
Honda Accord (2013 - 2015)
Oct 6, 2019 12:50 PM
Mypacklouder
Nov 16, 2018 04:32 PM
