Help! B20B Swap in 91 EF, won’t crank
First off, I would love to thank everyone here. I figured out most of this swap. Currently running into a few things.
The car won’t crank, I have a High Comp. B20B, P75 ECU, and I’m using a 91 CRX Harness.
I jumped the ECU OBO2a, jumped to 1, with extension to 0. I was going to do a CFK bypass but I’m not sure if it will work, since the harness doesn’t have it or am I wrong?
I also have it all hooked up, it looks like the ECU is working since fuel was pushed through and oil. The check engine light turned off and I did a cycle through. I have all grounds, And hoses are hooked up and relocated the battery to the back for space.
Any ideas?
Any ideas?
Also I have a Cable to Hydro Conversion kit installed. I’m not sure if the push rod is pushing the clutch level.
I was going to attempt to see how far back I can get it to push.
Might need more info before anyone could do more than guess. Does the starter click? You say you have fuel: have you checked pressure and if so, where? How does the oil indicate a good ecu? How was the battery relocate done (wire gauge/length, new ground point location)? Have you checked continuity on all grounds and made sure they are clean?
Edit: forgot the most important thing: is the clutch safety switch verified working?
The Battery Relocation, I bought a kit and the ground is direct to chassis as well, everything lights up.
Jud-Boosts
31
Sep 23, 2012 08:12 PM
love_ek9's
21
Nov 25, 2010 10:53 PM
MarsEf9
May 25, 2010 12:08 PM
