Slave Cylinder is Toast... need part number.
Old Nov 16, 2002 | 07:15 PM
integra_gsr98's Avatar
Default Slave Cylinder is Toast... need part number.
Are there any differences between the B Series slave cylinders? And if so, does anyone have the part number for the GSR slave cylinder?
Thanks.
Old Nov 16, 2002 | 07:25 PM
ragejed's Avatar
Default Re: Slave Cylinder is Toast... need part number. (integra_gsr98)
http://www.acuraautomotiveparts.net
Edit http://www.acuraautomotiveparts.net/...ASTER+CYLINDER
How do slave cylinders go?
[Modified by ragejed, 8:27 PM 11/16/2002]
Old Nov 16, 2002 | 07:31 PM
Default Re: Slave Cylinder is Toast... need part number. (ragejed)
Go as in go bad? The seals go bad and they leak causing a lack of pedal pressure, or in my case, no pedal pressure.
Old Nov 16, 2002 | 07:34 PM
ragejed's Avatar
Why do the seals go? I have a act hd clutch...would that put more wear on them? I am also think about the SS clutch lines http://www.fastlineperformance.com/clutchline.htm
Hope those wont do any damage.
Old Nov 16, 2002 | 07:39 PM
They are just regular wear items.. I don't know if heavy duty clutches cause a problem with them or not. I run the ACT Xtreme w/ a 6 puck unsprung, but have had to replace them on friends cars w/ stock clutches in them as well.
Old Nov 17, 2002 | 08:45 AM
Junior_r's Avatar
46930-SR3-013
EscoSi
Suspension & Brakes
Jun 6, 2014 10:23 AM
jonina
15
Jun 1, 2012 08:19 PM
1badcrx
Nov 28, 2011 08:49 AM
Born2Build
May 22, 2011 06:02 PM
zirac50
Aug 3, 2008 05:11 AM
