Issue with Honda Civic Ex 1.7 Vtech
I have p0302, p0303, p0304, and now p1457 codes. Which I know are misfire cylinder 2, 3, 4, random misfire and EVA.
I've recently changed because these needed to be done. Spark plugs, coils, catalyic converter, timing belt, valve adjustment, valve cover casket and crankshaft sensor
still getting codes above and now the new one any ideas as to why I am still getting the code? Would changing out the fuel filter help or would it be more than just the fuel since that is the only area so far I have not checked?
I also changed the cam sensor however eventually the codes p0302 p0303 p0304 and p0300 came back but p1457 is gone.
Last edited by Donald Deese; Apr 29, 2021 at 11:39 AM. Reason: Added maintance parts
Check for these common issues with these cars: breached head gasket and a failed By-pass (Canister) Shut Valve (CVS)/Canister
Use only OEM Honda sensors and spark plugs.
Injectors are ok. compression is good fuel pressure was not checked because when the cat was discovered with a clog they took it loose and the problem right than went away but did come back up again.
Jokez
Jun 21, 2021 08:57 PM
robbversion1
Oct 9, 2009 09:47 AM
